Max temp error, then blank screen, now printer stops while printing.
Page 3 / 6
Scottyos
(@scottyos)
RE: Max temp error, then blank screen, now printer stops while printing.
I can check them again here
Posted : 08/01/2023 2:48 am
Hello
(@hello)
does it turn on yet
Posted : 08/01/2023 2:49 am
Hello
(@hello)
have you tryed turning it on again
Posted : 08/01/2023 2:53 am
Scottyos
(@scottyos)
not just yet. fuses are good. I'm just popping everything back in quickly
Posted : 08/01/2023 2:57 am
Hello
(@hello)
only plug in the things i told you last time
Posted : 08/01/2023 2:59 am
Scottyos
(@scottyos)
just plugged everything in and it started up what appears to be fine.
Posted : 08/01/2023 3:02 am
Scottyos
(@scottyos)
I'll turn it off and try disconnecting a few of the items
Hello
(@hello)
what did you plug in
Scottyos
(@scottyos)
Just disconnected the things not mentioned and it has turned on now.
Posted : 08/01/2023 3:05 am
Hello
(@hello)
unplug anything to do with extruder except the pinda
Posted : 08/01/2023 3:06 am
Scottyos
(@scottyos)
Right now I have all the motors the pinda probe, the lcd cables and power panic plugged in.
Hello
(@hello)
perfect
Posted : 08/01/2023 3:07 am
Hello
(@hello)
now plug in the heatbed
Scottyos
(@scottyos)
I removed the extruder motor plug in.
Posted : 08/01/2023 3:08 am
Scottyos
(@scottyos)
I have the heatbed plugged in on the bottom but did you mean heatbed thermister?
Posted : 08/01/2023 3:09 am
Hello
(@hello)
yes good now when the heatbed is pluged in heat it to 70c degress
Hello
(@hello)
both
Posted : 08/01/2023 3:10 am
Hello
(@hello)
heat bed and heatbed thermistor
Posted : 08/01/2023 3:11 am
Scottyos
(@scottyos)
Just starting it up now.
Posted : 08/01/2023 3:12 am
Hello
(@hello)
ok once at 80 let me know if you get any errors
Page 3 / 6
