Marlin 2.0 on i3 MK3
Pasubio
(@pasubio)
Hi all,
I need to test some Marlin 2.0 experimental features on my i3 MK3 machine, so I'd like to know which is the best procedure to configure Marlin firmware and compile it for the printer.
I tried to implement the desired features into last Prusa firmware, but I think this is not the right way to go.
Thank you!
Postato : 13/09/2019 8:50 am
Pasubio
(@pasubio)
RE: Marlin 2.0 on i3 MK3
do you think that just trying to integrate in the original Prusa firmware some particular Marlin features can be a viable solution?
I mean integrating the desired .h and .cpp files, definitions, codes and dependacies, roughly speaking...
Thank you!
Postato : 16/09/2019 7:07 am
Pasubio
(@pasubio)
any news from someone about this topic?
Thank you!
Postato : 20/01/2020 2:22 pm
Nikolai
(@nikolai)
I think Marlin dev. forums would be better place to ask. You're trying to run Marlin firmware on the Einsy board. It's not really MK3 related.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 20/01/2020 5:51 pm
1 persone hanno apprezzato
