Manually laxing thermal runaway parameters?
I rarely print PLA, but a friend asked me for a LOTR ring... Ultradetail 0.05, Prusa PLA
Brim or no brim, after the first layer (when the fan starts), I get Thermal Runaway error after a minute or so. Tried three times, same result. Switched back to ABS, no problem.
Tried setting the fan to 80% in Slic3r, same.
Should I reduce the fan even lower? I'd rather just disable/lower-the-threshold this annoying alert. can I? how?
Publié : 12/09/2019 10:46 am
RE: Manually laxing thermal runaway parameters?
Check the alignment of your part cooling fan and ensure it's pointing towards the tip of the nozzle and not the heater block. You might also consider using a silicone sock on the block to keep temperatures more consistent. You can reduce your cooling fan speeds in the meantime, but you do want good cooling for printing PLA.
Publié : 12/09/2019 3:38 pm
