M600 Unload - button doesn't respond
Paul B
(@paul-b)
I tried a multi filament print using the Prusa Slicer select layers feature. My MK3s starts the print well and gets to the first filament change point. Then it stops, moves the print head to the right, and beeps with the display saying "push the button to unload filament". All precisely according to plan. But pushing the button does nothing. The filament stays exactly where it is. No motion of the extruded as happens on a normal unload. I am running firmware 3.7.1 on a MK3s. Any pointers or help?
Napsal : 29/06/2019 5:28 pm
Peter M
(@peter-m)
RE: M600 Unload - button doesn't respond
A few days ago i did this and it worked.
What do you see on the screen off the printer? choose filament?
Can you make use off the menu, to do the job.
Napsal : 29/06/2019 7:17 pm
