M600 problem firmware 3.1.3-245
Hi folks,
I sliced a file in Prusa Control it should have5 colour changes using the M600 command...
I loaded the file and the first two colour changes failed to activate the colourchange process.
I checked the commands were in the file... which they were.
I changed the filename and added an additional M600 right at the beginning of the Gcode
and ran it again...
this time the first (additional ) M600 activated the colour change script,
has anyone else seen this happen?
Publié : 21/04/2018 12:32 am
lowboydrvr
(@lowboydrvr)
Re: M600 problem firmware 3.1.3-245
Sorry Joan....I have not seen this issue. I have completed approximately 10 different color prints (each having 4 color changes) and all worked flawlessly.
Publié : 21/04/2018 1:29 am
oddly the file seems to be progressing normally now...
Confused!
Joan
Publié : 21/04/2018 1:56 am
