M112 Emergency Stop
garethsnaim
(@garethsnaim)
M112 Emergency Stop
Hi there.
I am not sure if its related to this
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/error-min-bed-temp/
But today I cam downstairs to find my print had an emergency stop M112 stop.
There was nothing else, is there a way for me to understand why it did this? logs or what ever?
As far as I am aware the temperature last night was circa 14 may have got lower but this printer is in a box and had already been running for hours so would it still be expected to fail even though its already hot?
Any advice gratefully received, I was 24 hours into this print. Sigh.
Opublikowany : 17/11/2020 7:21 am
Hotzenplotz
(@hotzenplotz)
RE: M112 Emergency Stop
Check your thermistor wiring: Anything damaged?
If this happens while printing, mostb of the time the connection to the hotend thermistor is bad.
Opublikowany : 17/11/2020 10:41 am
This not an uncommon error on the MK3S.  It was common under the last version of the Firmware.  Check to make sure you are under the most recent version.  I still get the error once a month but it is not weekly like before and I have 8 of these bad boys.
Opublikowany : 17/11/2020 10:50 am
garethsnaim
(@garethsnaim)
Hi is there like support I can speak with, I can only assume its hardware.
I moved it into my office and have watched it like a hawk. On a print tonight in a nice warm office it just suddenly stopped saying 'restart, min bed temp fixed'
I have checked the wires they look good to me.
Opublikowany : 18/11/2020 8:08 pm
