Loud clicking/knocking sound
Hi
I've had my new MK3S+ for a few weeks now and its been a dream up til the past few days when I've started getting a loud clicking or knocking sound - I've attached a video which should illustrate the problem. Would be really grateful if someone could suggest a possible cause? It seems to happen most when the printer is making diagonal or circular movements, so movements on both the x and y axes. Would this be caused by a bearing issue?
Thanks in advance!
Are you able to identify the source of the cracking?
Did you get your printer fully assembled or as a kit ...and more and more questions.
RE: Loud clicking/knocking sound
Can you isolate the noise to a specific axis? To me it looked more like on Y axis move than X. Try pressing gently on the fingerprint areas of the heatbed while it is happening.... if it changes or goes away it would be Y axis.
Or, maybe try a rectangular print with little combined movement, where just Y or just X is mostly being used at one time.
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говоÑÑ Ð¿Ð¾-ÑÑÑÑки но не оÑÐµÐ½Ñ Ñ
оÑоÑо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
I have what I think is the exact noise. When did you get your printer?
Mine is most definitely coming from the Y axis. Just got the printer 2 weeks ago fully assembled version.
Large infill pattern.
