Lots of strings with PLA
How do I get rid of this stringiness with PLA+? Using the latest version of Prusaslicer.
Este debate ha sido modificado el hace 5 years por Steve
Senior Life member of IEEE.
Respondido : 06/05/2021 9:41 pm
RE: Lots of strings with PLA
To start with, you have an overhang problem with your part: you need to print at a smaller layer height to make that internal stringing go away.
But -settings are crucial here. Did you use default profiles? Posting a copy of your project will get you the best help -- save the sliced project after building the gcode, zip the saved project file (XXX.3MF --> XXX.ZIP), then post here.
Respondido : 07/05/2021 12:19 am
1 les gusta
