lose imported profiles
If I import a filament profile and close the program, the profile is lost by the next start.
Do I forget something to do or is this a bug?
share my favorite adult xxx sites freeporn.ooo camjke.com pornsites.pro
Veröffentlicht : 18/06/2020 3:47 am
RE: lose imported profiles
Depends on what exactly you are doing. If you File>Import Config or Import from Project then that loads them but they are only temporary. You can then use the normal Save icon to save the one(s) you want into your settings.
If you use Import Config Bundle though then those get added permanently, that method pops a message with 'xx presets successfully imported' and on a restart those should be there.
Veröffentlicht : 18/06/2020 6:49 am
