Looking for 32bit version of slic3r for ubuntu (or other linux)
[Gelöst] Looking for 32bit version of slic3r for ubuntu (or other linux)
Filipp Freimann
(@filipp-freimann)
Hello friends of prusa printers
I am owner of the Prusa i3 MK3. To slice I usually use slic3r. Now, I want to use my older laptop to slice directly in the studio (my workshop in the cellar). I googled for a 32 Bit version for Linux, but was not able to find one.
I have then found source code at https://github.com/slic3r/Slic3r , which I nearly managed to compile for 32 bit. Only the button "slice now" is missing after a successful build.
Anyone was successful with a 32 Bit Linux version?
Thanks in advance
φ
Dieses Thema wurde geändert Vor 7 years von Filipp Freimann
Veröffentlicht : 28/04/2019 5:46 am
Vojtěch
(@vojtech)
RE: Looking for 32bit version of slic3r for ubuntu (or other linux)
openSUSE packages (of v1.38) are here: https://build.opensuse.org/repositories/home:StefanBruens:3dPrinting/slic3r-prusa-edition
I suppose modifying the spec file for a newer version shouldn't be hard.
Veröffentlicht : 28/04/2019 1:59 pm
Filipp Freimann
(@filipp-freimann)
Hello vojtech
Thanks for your reply. Unfortunately I am not looking for 64-Bit suse-Built files, but for either source-code (/src/x86/ incl. makefile) or already built packages for 32-Bit ubuntu/debian.
Probably it ist there on your mentioned page. But among these 20 links I am a bit lost.
Greetings
φ
Veröffentlicht : 28/04/2019 3:34 pm
Vojtěch
(@vojtech)
I can't help with the Debian part, but yes, there are x86 binaries (RPM, for openSUSE) in the repository I provided a link to. (And yes, you're right, it's a maze.) Perhaps you may have a luck installing them with 'alien'.
Direct link: https://download.opensuse.org/repositories/home:/StefanBruens:/3dPrinting/openSUSE_Tumbleweed/i586/
Anyway, it's an old version, so you'll likely not be interested.
If you're looking for source code, then just clone the git at https://github.com/prusa3d/Slic3r.git or download it in a tarball https://github.com/prusa3d/Slic3r/archive/version_1.42.0-beta2.tar.gz It includes detailed build instructions.
Veröffentlicht : 28/04/2019 4:21 pm
Filipp Freimann
(@filipp-freimann)
Thanks again
Acutally cloning the github link ( https://github.com/prusa3d/Slic3r.git ) is where I started. Following the instructions did not help. I was missing something or it was not mentioned for 32-Bit Linux? I have got a lot of errors of missing libraries. Installing them afterwards did also not help. I got more and more missing libraries. When all the libraries were there, the process of compiling suddenly stopped, with no meaningfull error message.
And you are right also: I am looking for slic3r V. 1.42.
I try to contact the developers.
φ
Veröffentlicht : 28/04/2019 4:36 pm
Jason Tibbitts
(@jason-tibbitts)
I have a fork of the Fedora slic3r-prusa3d package updated to 1.42.0 beta2 at https://src.fedoraproject.org/fork/tibbs/rpms/slic3r-prusa3d .  I did a couple of scratch builds to make sure that it at least builds on i686; those can be downloaded until May 14 from https://koji.fedoraproject.org/koji/taskinfo?taskID=34540386 (Fedora 29) or https://koji.fedoraproject.org/koji/taskinfo?taskID=34540788 (Fedora 30).
I've no idea if they actually work properly, or if they would have any utility to an Ubuntu user.
Diese r Beitrag wurde geändert Vor 7 years von Jason Tibbitts
Veröffentlicht : 30/04/2019 6:40 am
Filipp Freimann
(@filipp-freimann)
Thanks for the links. Installing using "alien" and "dpkg -i" was no problem form the fedora rpm package. When I start "slic3r-prusa3d" I have got the error message "libwx_gtk3u ..." missing. Im my system (lubuntu 16.04) was only "libwx_gtk2u..." installed.
I am switching the system to lubuntu 18.10 today and will return here with my results.
φ
Veröffentlicht : 01/05/2019 5:25 am
Filipp Freimann
(@filipp-freimann)
I just upgraded the computer to lubuntu 18.10 (which is the neweset 32-bit verison, i have found for lubuntu).
Installig the fedora-package using alien and dpkg worked somehow.
Starting gives me the error
libboost_filesystem.so.1.69.0 missig
I have libboost_filesystem.so.1.67.0 installed (a newer version is not available for lubuntu).
Any Idea?
PS: compiling from scratch ( https://github.com/prusa3d/Slic3r/blob/master/doc/How%20to%20build%20-%20Linux%20et%20al.md) still fails on lubuntu 18.10 (32-Bit edition).
Thanks in advance
phi
Veröffentlicht : 01/05/2019 7:39 am
Spacemarine
(@spacemarine)
Out of curiosity, why do you prefer 32 bit Linux? Is your hardware too old to run 64 bit?
Veröffentlicht : 01/05/2019 10:12 am
Filipp Freimann
(@filipp-freimann)
yes. it is a 32Bit processor (lenovo X41 Tablet). (And this is even better than the old honeywell 6000, which had 6Bit for a Byte 😉
Diese r Beitrag wurde geändert Vor 7 years von Filipp Freimann
Veröffentlicht : 01/05/2019 10:30 am
Filipp Freimann
(@filipp-freimann)
After calling
cmake ..
(in src/build) I get the error
[ 66%] Completed 'googletest-download'
[100%] Built target googletest-download
CMake Error at libslic3r/CMakeLists.txt:4 (include):
include could not find load file:
PrecompiledHeader
-- Configuring incomplete, errors occurred!
See also "/home/vali/prusa3d/Slic3r/src/CMakeFiles/CMakeOutput.log".
See also "/home/vali/prusa3d/Slic3r/src/CMakeFiles/CMakeError.log".
Any Idea, what precompiledHeaders mean in this context?
Veröffentlicht : 01/05/2019 9:06 pm
Vojtěch
(@vojtech)
Posted by: filipp.f
Extra points for the ThinkPad X41, one of the nicest notebooks/tablets ever!
Veröffentlicht : 01/05/2019 9:16 pm
Filipp Freimann
(@filipp-freimann)
SOLVED: Looking for 32bit version of slic3r for ubuntu (or other linux)
It finally works! Thank you all.
I was such an idiot. after compiling the whole stuff in the /deps/ directory, I thought that I have to compile it again in the /src/ directory. There (in /src/) I allways got this PrecompiledHeader error. I have seen this morning, that after compiling everything in the /deps/ directory, there is the final verison in .../deps/src/ called .../deps/src/slic3r-gui. And ... IT WORKS!
To compile I added a lot of packages in my lubuntu 18.10 (see lubuntu18.10.markings). I was mostly confused, which 'curl' library (-dev version) I had to choose. The ones in the actual file (lubuntu18.10.markings) work, but are probably ways too many libraries.
And after creating a .../deps/build/-folder, call
cmake ..
and don't forget "make" afterwards directly within the ../deps/-directory (I switched to .../src/build/ and did the cmake .. there again; what a fail).
So thanks to all (especially vojtech-p6 and jason-t6).
phi
Veröffentlicht : 02/05/2019 5:51 am
Vojtěch
(@vojtech)
Veröffentlicht : 02/05/2019 6:13 am
