Location of custom slicer settings in prusaslicer linux appimage
Tasmedic
(@tasmedic)
I use Lubuntu, and have installed the prusaslicer appimage, to run my MK3S.
Now, I'm reinstalling linux and want to save all my customised slicer settings so I can reinstall them onto my new OS.
Can someone tell me where to find all my customised filament, printer, files, so I don't have to start all over again with a default appimage?
Many thanks
Dr Chris Kear
Tasmania.
Postato : 13/05/2021 1:30 am
idontwantapublicusername
(@idontwantapublicusername)
RE: Location of custom slicer settings in prusaslicer linux appimage
Most version of prusaslicer have their conf in ~/.config/prusa* and older ones were in ~/.prusa* if I remember correctly.
When in doubt, do
$ find ~ -iname "*prusa*"
The config directory moves around sometimes, look at the modification dates of the files.
edit: PrusaSlicer /not prusaslicer
Questo post è stato modificato 5 years fa da idontwantapublicusername
Postato : 13/05/2021 10:34 am
The best thing to do to save all custom settings (not any system ones) is to start PS and use File>Export>Export Config Bundle or Export Config bundle with physical printers.  That will save an ini file contains ALL custom Print, Filament and Printer profiles.  You can then restore then using the Import config bundle from the file menu.  The export config option only exports the currently selected in use print/filament/printer profiles.
It wont contain any system profiles though so after reinstallation you would need to run through the config wizard once to get those back.
A config bundle is commonly used to save snapshots of profiles and move them from machine to machine.
If you want to know where all the config files are located then Help>Show configuration folder in PS is how to locate them.
Postato : 13/05/2021 10:43 am
most likely ~/.config/PrusaSlicer
Postato : 13/05/2021 12:32 pm
Tasmedic
(@tasmedic)
@neophyl
Thanks ever so much for your help, which will save me a lot of time.
With my very best wishes
Chris
Postato : 13/05/2021 10:04 pm
Tasmedic
(@tasmedic)
@diem
Many thanks to you for your help.
Now, I can reinstall linux and not worry about all those hard-earned slicer settings!
One of the great thing about Prusa products is the community support.
Best wishes
Chris
Postato : 13/05/2021 10:05 pm
