        loading on printbed off center
Hi just reinstalled a new copy of PrusaSlicer and re flashed firmware on my MK3S...... but now my imported STL files sit on the printbed off center to the left.
How can i center the print before slicing?
                            Posted : 02/12/2019 3:28 pm
                    RE: loading on printbed off center
By default Slicer adds a new model to the centre of the defined print bed. If its off centre you could try clicking arrange and it will try to put the part (if singular) back in the middle. If you do that and its still not central then I would check your model in some stl viewer software to make sure there aren't any invisible vertices that are part of it. Stray vertices wont print and arent visible but will still be part of the model so make its boundary box different to what you expect.
                            Posted : 02/12/2019 7:32 pm
