Live Z adjust missing, while printing
Joey
 Joey
(@joey-2)
Dont see Live Z Adjust on the Info, Tune, Pause Print... screen.
Also cant get to it by holding down the knob?
Any clues? Thank you.
Mk3 - 1X
Mk3S - 2X
2021 Hyundai Palisade
Wife - 1X
Napsal : 18/01/2022 3:21 pm
RE: Live Z adjust missing, while printing
Not at the printer at the moment to check but I thought it was on the settings screen while printing.  Then again its been a long while since I've needed to adjust it while printing so might be remembering wrong.
Napsal : 18/01/2022 3:24 pm
Kas Hoogeveen
(@kas-hoogeveen)
Same problem.
Also, my printer seems to "forget" at what heigth it should start and prints just at the height after the 1'st calibration.
Same at your end?
Napsal : 24/01/2022 2:44 pm
Joey
 Joey
(@joey-2)
Kas
My print is fine. Live Z was nowhere to be found.
But now all is OK. I don't know what caused the display to go back to normal.
Mk3 - 1X
Mk3S - 2X
Wife - 1X
Napsal : 24/01/2022 4:34 pm
Kas Hoogeveen
(@kas-hoogeveen)
That's the weird part of it. Sometimes it works perfectly and the other time it forgets the z calibration and the live z is nowhere to be found.
Odd.
Napsal : 25/01/2022 9:40 am
Thunderbear
(@thunderbear)
Same here – Live adjust Z is missing from the main menu while printing. Pressing the knob for a few secs also doesn't do anything.
Weird. I swear I've seen it before.
I did a First Layer Calibration a few days ago ... I wonder if that might have anything to do with it?
Napsal : 26/04/2022 4:47 am
live Z is a first layer feature, it's not a lot of use on higher layers so I believe it is disabled after layer 1
Napsal : 26/04/2022 6:36 am
Thunderbear
(@thunderbear)
Ah, ok – thanks, Joan!
Napsal : 30/04/2022 8:40 pm
