Live Z adjust missing, while printing
Dont see Live Z Adjust on the Info, Tune, Pause Print... screen.
Also cant get to it by holding down the knob?
Any clues? Thank you.
Mk3 - 1X
Mk3S - 2X
2021 Hyundai Palisade
Wife - 1X
RE: Live Z adjust missing, while printing
Not at the printer at the moment to check but I thought it was on the settings screen while printing. Then again its been a long while since I've needed to adjust it while printing so might be remembering wrong.
Same problem.
Also, my printer seems to "forget" at what heigth it should start and prints just at the height after the 1'st calibration.
Same at your end?
Kas
My print is fine. Live Z was nowhere to be found.
But now all is OK. I don't know what caused the display to go back to normal.
Mk3 - 1X
Mk3S - 2X
Wife - 1X
That's the weird part of it. Sometimes it works perfectly and the other time it forgets the z calibration and the live z is nowhere to be found.
Odd.
Same here – Live adjust Z is missing from the main menu while printing. Pressing the knob for a few secs also doesn't do anything.
Weird. I swear I've seen it before.
I did a First Layer Calibration a few days ago ... I wonder if that might have anything to do with it?
live Z is a first layer feature, it's not a lot of use on higher layers so I believe it is disabled after layer 1
Ah, ok – thanks, Joan!
