Live Adjust Z...does nothing?
Joe
 Joe
(@joe-25)
After I moved 3dprinter it dosen't work anymore. The current problem is that Live Adjust Z seems to do nothing during the first layer of printing. I can twist the knob to change the Live Adjust Z value, but the extruder will not actually change in height and just keep extruding along X and Y like no one's business. During the pre-print calibration, the 9 points are still found, but as soon as the first layer actually starts, the extruder will rise up a little bit and start printing about 3-4mm above the bed rather than just above it. Factory reset, xyz calidration, update doesn't work.
Publié : 22/12/2022 10:58 am
RE: Live Adjust Z...does nothing?
I've never seen this, maybe the PINDA sensor was damaged while moving. I'd check the status of the sensor in the LCD display. If that looks okay, I'd get on the chat with Prusa support to help you with it.
Publié : 22/12/2022 11:05 am
Hello
(@hello)
Does it move up and down okay little movement if any thing loose could make it slip
Publié : 28/12/2022 7:27 pm
Hello
(@hello)
Try higher the pinda
Publié : 28/12/2022 7:28 pm
