Lithophane layers missing
VitruViper
(@vitruviper)
Looking to get some advice as to where to go. When trying to slice lithophanes in Alpha 4 and 5 my preview will lose layers and skip so the print fails. See attached picture. When I slice it in 1.41.2 there is no issue. Should I report this or is there may be some settings I need to look at. I should also mention that slicing anything else in the Alphas has had no issue. Only issue is with the Lithophanes.
Veröffentlicht : 10/02/2019 2:01 pm
rob.l6
(@rob-l6)
Re: Lithophane layers missing
Assume you have tried a non alpha, or a different slicer for comparison? That would narrow the issue down.
Veröffentlicht : 11/02/2019 3:16 am
VitruViper
(@vitruviper)
Yes the second screenshot is from the older version of slic3r PE and that has no issues slicing. Only seem to have the issue with the alpha.
Veröffentlicht : 11/02/2019 4:07 pm
rob.l6
(@rob-l6)
oops didn't read the image comment. I would report it.
Veröffentlicht : 12/02/2019 3:14 am
VitruViper
(@vitruviper)
Sorry for being ignorant about this but where would I go to submit this bug?
Veröffentlicht : 12/02/2019 9:36 pm
Flaviu
(@flaviu)
I made a report today because I encountered the same issue: https://github.com/prusa3d/Slic3r/issues/1869
Veröffentlicht : 25/02/2019 7:15 pm
Flaviu
(@flaviu)
Workaround for now is import/export the stl in Meshmixer.
Veröffentlicht : 01/03/2019 8:05 pm
VitruViper
(@vitruviper)
Thanks. I also found that if I right clicked and had it repaired through netfab it corrected it as well.
Veröffentlicht : 04/03/2019 1:37 am
Vojtěch Bubník
(@vojtech-bubnik)
Mitglied Admin
It was a regression issue, it was fixed with https://github.com/prusa3d/Slic3r/commit/c4829338453691371fc089d0aaf2cb9271417415
The fix will be part of the upcoming 1.42.0-beta
Veröffentlicht : 11/03/2019 7:05 pm
VitruViper
(@vitruviper)
Thank you.
Veröffentlicht : 12/03/2019 12:14 pm
