Lines on outside when solid layer
Byulos
(@byulos)
There is a line on the outside whenever there is a solid layer in the print. In this case it is the floor of the boat. Any ideas what could cause this?
Napsal : 19/08/2018 3:27 pm
Re: Lines on outside when solid layer
Is that the sample gcode provided by Prusa or one you sliced yourself?
Napsal : 19/08/2018 5:59 pm
Knickohr
(@knickohr)
Member Moderator
This is caused by wrong/bad/too much or less cooling. Try to optimize your colling settings.
Thomas
Napsal : 20/08/2018 9:18 am
Byulos
(@byulos)
Yes, this was the one preloaded on the SD card.
Napsal : 23/08/2018 9:31 pm
Byulos
(@byulos)
Thanks for the reply Thomas. I will work on my cooling.
Magnus
(@magnus-3)
I have the same problem.
What is the logic behind the cooling problem?
Regards
Magnus
Napsal : 25/08/2018 12:18 pm
RickM
(@rickm-3)
Did anyone figure out if cooling was the problem here?
Napsal : 01/03/2019 5:34 am
