Linear Advance Settings
Hello,
I installed the new Bondtech MK3 Extruder Upgrade ( https://www.bondtech.se/en/product/prusa-i3-mk2-5-mk3-extruder-upgrade/) to my MK3. I noticed very loud Extruder Clicks at each retract, which only went away after disabling Linear Advance. The Bondtech support backed that and said that the Prusa Linear Advance does not work well with 3:1 Extruders, but the newer Linear Advance in Marlin does. Is there a way to add that portion to my Firmware in order to try that?
Best Regards,
D.Lehmann
Opublikowany : 16/05/2019 10:35 am
