Life span of steel spring sheet
David Stephenson
(@david-stephenson)
I have had my Mk3 for maybe a year and a half. I don't know how many hours it has on it, but some weeks I run it half the day or more, especially now. I frequently print the same part over and over. Recently I've noticed the prints are curling up in certainly places and some of the first layer has trouble sticking. I use the same settings, the same gcode, the same filament over and over. I clean the steel sheet with IPA prior to every print. Looking around this forum I discovered the suggestion of soap and water for cleaning and I have done that. I have not yet cleaned even once with acetone mostly because I just don't have any and the alcohol seemed to have been working for all this time.
My question really is about knowing when the steel spring sheet needs to be replaced. My parts that I print leave "shadows" or impressions of themselves on the sheet. Some of them are just a kind of image footprint of the print, but on one side of the sheet there is an actual textured ripple of the footprint of the print from long-term use on that side. I'm wondering if those parts of the sheet are having some of the coating removed, or if there is PLA residue that is building up.
I am interested in tips on extending the life if possible, but if it's time to replace, then that's what I'll do.
Thanks in advance. If photos would help, I can post some.
Este debate ha sido modificado el hace 6 years por David Stephenson
Respondido : 27/04/2020 2:31 am
RE: Life span of steel spring sheet
Hi Davi,
I print PLA, PETG and TPU... more exotic filament may need different treatment
the Build plates are relatively robust.
treat them well and they will last a long time.
the major cause of curling, is loss of adhesion, and this is often due to a build up of surface contamination.
IPA can remove some contamination but doesn't remove all contamination.
there are lots of contending options.
I take my build plate to the sink, and wash it well with Hot Water and Dish Soap, then rinse well with fresh hot water, and dry immediately with plain paper towels.
(Normally after one of these messages there are a number of people saying not to do this or that or you must do something else... All I have said is that 'I' wash 'My build plates'...   I have a selection of smooth and textured build plates and so far, NONE of them have rusted...)
After washing and drying, I use my build plate, as normal, no other surface treatment... (exception... Wipe smooth plates with windex before printing PETG and TPU) the windex reduces your adhesion to prevent over adhesion
After some prints, you may see bubbles under the smooth PEI sheet, if you make sure that all of the waste filament is taken off the surface, turn the plate over, and use the other side... Normally the bubbles will dissapear after a few reheats.
Respondido : 27/04/2020 2:21 pm
nilok
(@nilok)
I just spoke to support about this.....as I have over 30 days of print time on a machine built in march.  The smooth sheet I am using on it has had over 500 prints removed form each side, and was starting to show shadows where the prints were.  I was always thorough about ISO wipes between prints and I use a method like joantabb's with a lot of hot water and Palmolive.  I just scrub the sheet with a microfiber cloth and soap.......then rinse and scrub with paper towels to dry.
Support had me track down a small bottle of 100% acetone (walgreen's $3.99 if idiots havent bought it all to try sanitizing covid) - and a scrub on both sides completely restored the sheet to new.  While the shadows are still there.....the adhesion and print quality is nearly brand new.  I was also hesitant to try acetone as it was hard to find currently, but it was so worth the trip, I returned that evening to deliver 40 relief bands to their employees.
Is your printer grinding? Bearings squeaking? Motors smoking?
Step 1) Wash your Steel Sheet
Step 2) Return to Step 1
Respondido : 27/04/2020 2:43 pm
David Stephenson
(@david-stephenson)
@nilok and @joantabb
Thank you very much for the feedback. I will use some acetone and I will more regularly use soap and water and try to get better adhesion. But I do still wonder how a person will ever determine when a plate is beyond its use life or worn out. I went ahead and ordered a new one to have on hand.
And, do you think those print "shadows" are from build up of material, or it is from a removal of surface material from the build plate when the parts are removed?
Thanks,
David
Respondido : 27/04/2020 3:05 pm
nilok
(@nilok)
Also.....I'm adding this here because even the pharmacy tech had to look it up: 100% Acetone is not 100%....at least not in the US......it has an added ingredient to add scent, and does not affect the PEI.  I wasted far too much time trying to find something that didn't exist.  Just be sure the bottle you buy has "Ingredients: Acetone, Denatonium Benzoate"
Respondido : 27/04/2020 3:08 pm
1 les gusta
nilok
(@nilok)
@davi-11
My shadows never went away........but like joantabb said, the bubbles should vanish if you flip the sheet for a few cycles.  I'm not sure if I'll get another 500 prints per side between acetone scrubs....but I can say for sure that I feel a $35 plate has given me full value with 1000 prints, and to get more out of it with a few dollars in cleaning, I am very impressed.  The cleaning/acetone/scrubs has also made me a little less "overprotective" of the sheets...but I cannot answer your question about lifespan.  I've only had my machines since January and March.....
Respondido : 27/04/2020 3:19 pm
1 les gusta
jwvaughn
(@jwvaughn)
Regarding 100% acetone.
I purchase one quart of 100% acetone at a hardware store, no scent added, for $8.00 U.S.  I checked the manufacturs specs and nothing by acetone.
The scented stuff is sold for use as fingernail polish remover.
Jerry
Respondido : 27/04/2020 9:02 pm
1 les gusta
nilok
(@nilok)
@jerry-v2
Sorry, I should have been more specific. I was referring to sources other than the hardware/paint store where a single ingredient is clearly labeled. Some idiots here ran stories about acetone being substituted for alcohol to disinfect surfaces.....and there isn't much to be found anywhere.  My wife was the one who suggested nail polish remover without any extras....was just hard to find 100%, and I wasn't used to seeing anything extra added. 100% doesn't seem to leave room for an extra ingredient....but it is labeled as such.
Respondido : 27/04/2020 9:20 pm
1 les gusta
JBinFL
(@jbinfl)
Good advice already in this thread...  A couple of things.
I have a PC sheet that I got in June 2018 and have used since in addition to a couple of others...  I have a couple of shadows that have accumulated from various prints during this time and the shadows themselves do not seem to have affected the print adhesion...  I believe, with not proof to back it up, that the shadows are some sort of damage to the surface of the plate from the print removal, however slight....
In addition to surface contamination, drafts will cause print lifting so that is something to be mindful of....
You indicate that you print the same prints with the same filament.  It could be beneficial to move the prints around on the build plate for different prints to spread the wear so to speak.  That may mean that you have to have a couple of different Gcodes for the same prints to use different areas of the plate to print on.  Again, I have no proof that that will help extend the life of the sheet, but it makes intuitive sense if for nothing else than allowing for more areas subject to contamination or wear on the plates...  it is something I try to do on prints.
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Respondido : 28/04/2020 1:51 am
1 les gusta
Miembro
I have plates that are 2 years old and still printing.  Some are scuffed and scarred but still print.
Respondido : 28/04/2020 10:32 am
1 les gusta
David Stephenson
(@david-stephenson)
Good advice everyone, thank you.
I found some acetone and gave my sheet a good scrubbing with a paper towel and the acetone took the shadows right off. That means it was a build up of some material instead of a removal of material from the sheet.
I still have a bunch of divots, maybe from stray bits of debris between the sheet and heat bed. They have not self-healed after heating, but it has not created any problems with printing.
Respondido : 28/04/2020 1:31 pm
Dave J
(@dave-j)
If you are printing the same item repeatedly, like the RC3 shields, make four GCODE files, each rotated by 90 deg, i.e rotate the STL file in PrusaSlicer by 0, 90, 180, 270 deg in the Z-axis.
After printing 20 RC3s I noticed my steel sheet looking a bit ropey, but now I rotate the prints the sheet looks almost as good as it did when I first stated. Also, the usual point where the RC3s lift from the bed is where the elastic attaches. Since these are printed on a different area of the sheet for each of four prints, they don't lift anymore. So less cleaning required.
Cheers,Dave Jackson"Enthralled Nooby (not so much maybe, ~58 years old)... If 3d printers had been around 40 years ago... "
Respondido : 29/04/2020 9:25 am
Miembro
@david-j21
Good advice.  I will have to try it.
Respondido : 29/04/2020 9:33 am
Thejiral
(@thejiral)
It's an old thread but I was also starting to wonder about the life span of smooth steel plates. I have mine now for one year of relatively frequent usage and I print only on one side as the other side has taken quite a beating from printing Nylon and I thought I reserve that side for stuff like that.
Recently I have the feeling that adhesion has deteriorated substantially, also after giving it a repeated wash with detergent. So I used a bit of acetone for the first time and it seemed to help but only for a few prints even though I was super careful not to leave finger prints and cleaned with IPA in between. Maybe it isn't a problem so much with the sheet but with using a 0.25 mm nozzle or maybe I need to recalibrate the Z level but I was wondering what the experience of others here is regarding the life span of those plates. If the PEI sheet looks undamaged does it nonetheless loose its adhesion qualities at some point beyond recovery of all those means frequently described? Or should it stay sticky if properly cleaned and with proper 1st level calibration?
Respondido : 01/02/2021 8:01 am
Miembro
@thejiral
A year is pretty good. The more adhesive and abrasive the material, the shorter the life span.
If Acetone did not work, get some 2000-3000 grit sandpaper.  It works pretty well with small circles in each section of the plate.
Respondido : 01/02/2021 11:19 am
Thejiral
(@thejiral)
Thanks, good to know. I'll certainly get a new sheet. After all having a second one can't be wrong and I'll have the first one still for the nasty stuff and for PP.
I will try out that sandpaper approach though.
Respondido : 02/02/2021 7:21 am
Miembro
@thejiral
My original first sheet just died after 3 years.  I would say 1-2 years is a good long life if you are printing sticky filaments.  Longer if you stick to PLA.  Anything after that is gravy.
Respondido : 02/02/2021 11:29 am
