Left hot end fan wiring error
Montynator
(@montynator)
I get the left  hot end fan wiring error during  self test with mk3s and firmware 3.5.1-3518.
I had replaced the left hot end fan with another oficia one purchased in the Prusa Store, but it still doesn’t work ... any Idea?
Publié : 01/04/2021 4:17 pm
Baklin
(@baklin)
RE: Left hot end fan wiring error
You could swap the left hotend fan and the front print fan on the Einsy board. If the error is now on the front print fan you have a wiring problem. It the error stays on the left hotend fan you have a broken Einsy board or connector on the board.
Publié : 01/04/2021 5:44 pm
Montynator
(@montynator)
Thanks for the fast answer. I will try and inform about the results
Publié : 01/04/2021 5:52 pm
Montynator
(@montynator)
Changing the fan plugs the problem changes to front fan soooo ...
I will change the einsy board
Publié : 01/04/2021 10:17 pm
