Layer Shift after Filament Change
I've been having issues with X axis layer shifts after a filament change, both configured in the slicer, and using the Tune menu feature, on my MK3S+ (firmware version 3.14.1-8237). When the shifts started, I checked belt alignment, tension, and cleaned/lubed the rods. I've done a XYZ calibration, tested multiple models, used different slicers (Prusa Slicer and Orca), and noticed the Pinda probe wire had popped out of the channel. So I reseated, and redid the XYZ calibration. No change after all of this.
If I do multiple filament swaps, it "almost" corrects itself. Weird.
Any ideas on where to go from here? I don't get any layer shifts on a single color/material print, just filament changes.
Ce sujet a été modifié il y a 4 months par omegared13
Publié : 26/12/2025 10:25 pm
