Layer lines and Z size
I'm getting layer lines, on all sides. The print is also too short, by the number of layer lines x average layer height. It is as if the Z axis sometimes doesn't move up when it is time to print the next layer.
- MK3S
- Revo 6 0.4 nozzle
- PrusaSlicer 2.7.1
- Firmware 3.13.2-RC1-7068
Print settings:
- 0.2mm Quality, with variable layer height
Protopasta HTPLA
Napsal : 07/01/2024 6:18 pm
Topic starter
answered:
RE: Layer lines and Z size
I chatted with Prusa tech and he suggested that the problem may be similar to the benchy hull line issue:
https://help.prusa3d.com/article/the-benchy-hull-line_124745
I them reprinted with 0.2 layers instead of variable. It came out great. Apparently this is a bad interaction with variable layer lines and this particular model.
Napsal : 13/01/2024 3:51 pm
