[Gelöst] Language-problems after update
Schehlein
(@schehlein)
Hey there!
Perhaps you can help me with that issue.
I just updated my I3 MK3S to firmware 3.10.0. At first everything wnt fine but after the reboot my printer asked me wich language I want to use. I chose German and the printer rebooted again and askes again about the language. I tried it several times but there was no possibility to set the language to German. I tried to choose English and it worked. Then I tried to set the language in the settings-menu tu German but it also failed. The printer did a reboot and showed up the language selection.
What am I doing wrong?
Berst regards and thanks for your aid in advance!
Bernd
Veröffentlicht : 22/05/2021 4:07 pm
RE: Language-problems after update
did the printer ask you to press the button to select the language?
If so, did you press the LCD Control knob, or the X (RESET)button?
Joan
Veröffentlicht : 22/05/2021 4:59 pm
Schehlein
(@schehlein)
@joantabb
Hey Joan.
Thank you for your prompt answer. I did not press the the „X“ button. I pressed the button in the middle of the dial.
Bernd
Attachment removed
Veröffentlicht : 22/05/2021 5:08 pm
Schehlein
(@schehlein)
The problem is solved! I flashed the printer again and everything seems to work now!
Thank you for your aid!
Veröffentlicht : 22/05/2021 5:24 pm
