Knocking sounds while printing
Roy
 Roy
(@roy-3)
FullSizeRender
Hello, I recently finished building a Prusa i3 MK3S+ and so far it’s printing really well. While printing however there’s a repetitive knocking sound, like some kind of traditional chant. This happens in particular when printing the diagonal fill lines. I’m attaching a video showing this behavior. Does anyone know what causes this and how it can be fixed?
Publié : 14/07/2021 10:16 pm
Roy
 Roy
(@roy-3)
Embeded video doesn't work but the link does
Something seems to be wrong with the attached video, but the oddly named link on the top (FullSizeRender) works 🙂
Publié : 15/07/2021 9:31 am
This is annoying
The slight knock on direction change is normal.
You can try using stealth mode.
 If that's not enough go to Printer Settings > Machine limits Where you can set acceleration and jerk limits.
Publié : 15/07/2021 11:23 am
Roy
 Roy
(@roy-3)
Thanks
Thank you. The knocking is not only on direction change, it happens also on straight motion when the machine makes diagonal lines. A second noise I was wondering about is a woosh when the Y axis moves slightly faster. The X axis doesn't make such a noise and I was wondering if this has to do with the belt tension or some rotating part that might be slightly touching a stationary part.
Publié : 15/07/2021 2:30 pm
jimmy
(@jimmy-3)
think its okay
it's normal. always wondered why my mk3s is riding a horse 😀 when printing. think it has something to do how the steppers are powered or something. i use dry bearings so, it's not your bearings  at least.
Publié : 15/07/2021 6:07 pm
