it or i messed up
xt550
(@xt550)
it or i messed up
Hello.
so i have had some problem with the first layer but i think i solved the problem, but the last cm of the prusa pla gut stuck in the extruder so i clean'd it out and may have got it to closet o the cooler anyway i got the mother of all jams/cloged extruder so i damaged the heater and the thermometer tryng to clean it i also broke the tube conecting the cooler so now i need those parts new and cant find it on the site.
How do i get a new hot end complete and the tube/pipe that connect's with the cooler
Publié : 05/05/2019 3:08 pm
vintagepc
(@vintagepc)
Membre
RE: it or i messed up
Make sure you are logged in; the store is controlled by what is in your purchase history, so if you are not signed in you will not see parts for the printer(s) you have bought.
If you still don't see it use the live chat feature in the store to contact support. They will help you get your account fixed so you can see/buy the parts.
Publié : 05/05/2019 3:59 pm
xt550
(@xt550)
it there a recomended distance betwin  the hotend and the cooler?
Publié : 05/05/2019 4:19 pm
vintagepc
(@vintagepc)
Membre
Does this guide answer your question?
https://www.matterhackers.com/articles/how-to-assemble-an-e3d-v6-all-metal-hotend?gclid=Cj0KCQjw4fHkBRDcARIsACV58_HMzgPMORZiQJhrCMM23VBG0JWvbyw4PLEM4-Fi14JX11yKWa8PekgaAhOtEALw_wcB
Publié : 05/05/2019 4:35 pm
Vojtěch
(@vojtech)
Posted by: svante.n
MK3 pre-assembled hot-end and MK3 PTFE Tube
Make sure you're logged in before clicking on the link. It will not work unless you're logged in.
Publié : 05/05/2019 5:03 pm
Vojtěch
(@vojtech)
Posted by: svante.n
That is defined by the position of the nozzle in the heater block. The nozzle should be first tightened against the heater block and then turned one full turn back. Then you screw in the heat break until it touches the nozzle. Then you assemble your printer. Then you heat up to 285 °C and tighten to 3 Nm.
But if you don't want to go through all that, get the pre-assembled hot end from Prusa.
Publié : 05/05/2019 5:05 pm
