Issues with Thermal run away error on new profiles
So the default profile seam to be setting fan speed to max, when sliced with this i get thermal run away.
having to change this every print is being a pain any ideas why max fan speed would cause this error?
Veröffentlicht : 05/01/2023 12:06 am
if you have built the extruder wrong the fan can be blowing onto the heat block making the thermistor thinking its diffrent temprature please take photo of extruder
thanks in advance
Veröffentlicht : 05/01/2023 12:41 am
