Issues I have since 3.13.2 firmware
jmshaffer1973
(@jmshaffer1973)
Hello:
After the print, my heat bed stays live.  Before the firmware update, when the print was done, the heat bed heater turned off.  I've had this printer for a few years now and this is a new scenario.  Also, I don't like the fact that the status time shows how long it's been printing versus the old way where it would show estimated time remaining.  The heat bed staying on is a real safety concern for me as I sometimes start a print job before bed.  It's also a huge waste of electricity.  Anyone else experience this?  I can go into preheat mode and turn cooling on which then shuts down the heater.....
Justin
Opublikowany : 23/12/2023 11:40 pm
jmshaffer1973
(@jmshaffer1973)
Also.....
I just noticed two more things. It's heating the bed prior to heating the hotend.  They used to heat simultaneously.  Also, after the 9 point Z calibration just prior to the print, it stops at the zero position and finishes heating the hot end.  It no longer does a purge wipe on the front of the plate and puts down a shitty skirt..... Just more things I found wrong.
Opublikowany : 24/12/2023 12:00 am
