Issue with PLA not sticking and curling
stoefln
(@stoefln)
Hi there!
Since I switched between ABS and PLA a couple of times, and then once had PLA in the printer, but printed with the ABS settings, it seems that printing is less reliable. I printed an ABS part sometime after that incident, which turned out perfectly well. So I don't know if my current issue is related to that incident.
My current issue is this: recently I switched back to PLA, and I can't get anything printed anymore. The PLA first layer is not sticking at all and it's curling up. Does this look familiar to you? (This is the first line the printer draws before the actual print)
Opublikowany : 30/11/2023 4:29 pm
