Issue - Impossible to print
Michel.1420
(@michel-1420)
Sorry about the blast but I'm running in an issue with my Prusa MK3S (born like this, not an upgrade).
I experienced for the first time an issue with the filament. It broke just before the ptfe. I dismount the extruder, removed the ptfe (where the filament was inserted and blocked) and replaced it with a new one. However it doesn't work as expected. When I try to reinsert my filament, the filament is inserted and after a while (2 or 3 sec) I heard several sounds (something like "clack, clack") and it stopped without having anything coming out from the extruder.
I may suppose that this is a common issue.. however I'm stuck with it and doesn't know how to solve it. I thought about changing completely the hotend but before going this way, I'd like to know if it might be possible to solve this issue easier.
Thanks a lot ...
Posted : 22/06/2021 6:27 pm
Lichtjaeger
(@lichtjaeger)
RE: Issue - Impossible to print
https://help.prusa3d.com/en/article/clogged-nozzle-hotend-mk3s-mk2-5s_2008
Posted : 22/06/2021 6:37 pm
Michel.1420
(@michel-1420)
I made all the steps of it .... except the last one ... 🙁
Posted : 22/06/2021 6:45 pm
