Is there some way to simplify extruder disassembly?
Michiel Helvensteijn
(@michiel-helvensteijn)
I occasionally find myself having to disassemble the extruder carriage in order to remove something that's blocking the filament path. As it turns out, this requires me to disconnect all wires from inside the control box and remove the cable sleeve and all zip-ties.
Has someone come up with a way to simplify this process? I know I can't be the first to have encountered this issue. Knowing the 3D printing community, someone will have designed a solution and shared it, but my Google fu is failing me.
In case there isn't already a solution out there, the simplest one I can think of is to insert connectors for all wires entering the assembly, and a 3D-printed clamp of some sort to secure the wire bundle (in lieu of zip-ties) and prevent strain on the individual wires. But I'd like some feedback on this idea, and some guidance w.r.t. what type of connectors to use, and so on.
Thanks!
Publié : 08/10/2019 9:12 pm
RE: Is there some way to simplify extruder disassembly?
I cut the filament off at the top of the PTFE Tube, leave the idler door open
heat the extruder to about 280C for a couple of minutes then push a long 1.5mm hex key onto the cue end of the filament and push firmly.
if it doesnt move, remove the nozzle and try again.
if the filament moves after removing the nozzle you probably have junk in the nozzle,  clean out or replace as you see fit!
Joan
Publié : 09/10/2019 12:23 am
1 personnes ont aimé
Laura F Farrell
(@laura-f-farrell)
Posted by: @joantabb
So I'm not the only person who does this!!
The MK3S update is an improvement here - you can leave the body on and just remove the covers. it would be nice if the "channel" for the wiring kept the wiring in place also.
But agreed it is messy - it takes a long time to get the extruder exactly right and a refit sometimes can mess up a perfect setup
Publié : 09/10/2019 2:47 pm
Chocki
(@chocki)
You can also use a brass welding rod, I got this tip from the forum, the brass is 1.6 to 1.7mm diameter and being brass wont damage your heat break or nozzle.
Publié : 09/10/2019 5:02 pm
Thanks all! Will definitely try this.
The purpose behind the post was more about simplifying disassembly in general, rather than just resolving a clogged hotend. But I'll be happy if I can solve the main cause my problems. 🙂
Publié : 09/10/2019 7:12 pm
ACE
 ACE
(@ace-2)
You could print and use a more service friendly extruder and switch to a geared one in the process. I've not looked back since changing to BNBSX (but that requires changing x-ends as well). I've also tried the skelestruder and some (not so successful) other designs. We do have options apart from R4...
Publié : 11/10/2019 12:30 pm
Chocki
(@chocki)
I can second skelestruder. I made and use one and it just works, but I think BNBSX will probably be easier to maintain, not that I have had to do anything to the skelestruder, it also allows a clearer view of the print nozzle.
Publié : 11/10/2019 12:49 pm
vintagepc
(@vintagepc)
Membre
Third vote for a skelestruder.
Publié : 11/10/2019 12:58 pm
