Is there any way to disable power panic on MK3S+?
So 99% i’m using sequential print mode for my project (this method suitable for my electricity condition). The situation is when power goes down and power panic works, the print head move aside the print object and i’m afraid the print head will crashed into the previous finished object. Is there any option to disable this feature in a proper way? I prefer to have one failed print object than broke my print head.
thank you.
Napsal : 01/06/2023 3:57 pm
RE: Is there any way to disable power panic on MK3S+?
First off you probably won't brake print head the belt would just slip I believe removing the power panic wire from PSU will do it but.
Napsal : 01/06/2023 7:00 pm
