Is there any possibility to stop printing via PC
zdenek.c2
(@zdenek-c2)
Hi all,
Is there any possibility to stop a printing via a PC if I'm printing from SD card. I'm using web-camera to see printing progress and I'm able to control PC via Remote Desktop Connection ......
Thanks,
Zdenek
Veröffentlicht : 14/05/2018 1:12 pm
Shoey
(@shoey)
Re: Is there any possibility to stop printing via PC
If you're tethered to the printer, issue an M25 code through Pronterface....Why not use OctoPrint?
Joe
Veröffentlicht : 14/05/2018 2:04 pm
Beware. If you try and initiate pronterface after starting a print. The connevtion process will stop the print.... and if the pc goes to sleep its likely to stop the print too.
Joan.
Veröffentlicht : 14/05/2018 3:23 pm
stahlfabrik
(@stahlfabrik)
When you reconnect to the printer, it resets, which stops any print.
Veröffentlicht : 14/05/2018 9:57 pm
