Is there any possibility to stop printing via PC
Hi all,
Is there any possibility to stop a printing via a PC if I'm printing from SD card. I'm using web-camera to see printing progress and I'm able to control PC via Remote Desktop Connection ......
Thanks,
Zdenek
Re: Is there any possibility to stop printing via PC
If you're tethered to the printer, issue an M25 code through Pronterface....Why not use OctoPrint?
Joe
Beware. If you try and initiate pronterface after starting a print. The connevtion process will stop the print.... and if the pc goes to sleep its likely to stop the print too.
Joan.
When you reconnect to the printer, it resets, which stops any print.
