Is there a way to skip steps in the self-test?
horrorland42
(@horrorland42)
I recently had to pretty much reconstruct the entire extruder due to a pretty careless mistake on my part, and now that I've got it mostly re-assembled, I need to check the belt tension on the X-axis. However, the wire on the print fan is broken. I know it's broken, I have a replacement coming but it'll take like a week to get here, and I want to be able to print things in the meantime.
I just want to be able to check the belt tension, however as far as I know the tension number (under the support menu) only updates after a selfcheck, which fails after the second step of the check because of the broken fan.
I disabled "check fans" in the menu, but that seems to only effect actual prints and not the self-test
Napsal : 16/05/2020 7:53 pm
daniel-9
(@daniel-9)
RE: Is there a way to skip steps in the self-test?
Run the Belt Test, it should be right above the Self-test in the configuration menu.
Napsal : 21/05/2020 8:49 pm
