Is pause printing changed ?
Mc_Fly
(@mc_fly)
When I want to print using two colors, I'm using this G code inserted in Tool change G-code:
G1 X220 Y220 F3600
G1 Z56 F720
M300 S1000 P500 ; Beep
M117 change color to xxx
M601 ; Pause
But today, when printer has paused, the menu that I got, does not offer the Unload filament option...
Only Stop printing, Resume and something else...
This was working before, has it changed with new firmware ?
Or I missing something ?
Thank you very much
Manel
Veröffentlicht : 15/11/2023 3:42 pm
Use M600 for tool/filament change.
Veröffentlicht : 15/11/2023 9:14 pm
Mc_Fly
(@mc_fly)
RE: Is pause printing changed ?
Hi Diem,
Yes... I know M600 and I was using it before read in a post that the sequence I'm want to use is better...
The change occurs outside the piece, so filament can not drop over your piece accidentally and you can add a message so you know what colour must be loaded.
But if pause cannot unload filament, I will come back to M600  ☹️
Thanks
Veröffentlicht : 15/11/2023 9:31 pm
From: https://cfl.prusa3d.com/display/PI3M3/Supported+G-codes
M600 - Initiate Filament change procedure M600: Filament change pause
Initiates Filament change, it is also used during Filament Runout Sensor process. If the M600 is triggered under 25mm it will do a Z-lift of 25mm to prevent a filament blob.
UsageM600 [ X | Y | Z | E | L | AUTO ] X - X position, default FILAMENTCHANGE_XPOSY - Y position, default FILAMENTCHANGE_YPOSZ - relative lift Z, default MIN_Z_FOR_SWAP.E - initial retract, default FILAMENTCHANGE_FIRSTRETRACTL - later retract distance for removal, default FILAMENTCHANGE_FINALRETRACTAUTO - Automatically (only with MMU)
So: Much of your code could be substituted by appropriate parameters for M600.
Veröffentlicht : 15/11/2023 11:40 pm
