Is my mk3s+ haunted ?
First time I post here, I have a Prusa MK3s+ that I bought end of 2021 and every part is original.I have never experienced any problem with it. Recently, each time I was slicing with PrusaSlicer I had a message telling me to upgrade to 3.11.1.
So I ended doing it, and I installed new firmware 3.12.1.
I'm usually using octoprint connected with a Raspberry Pi 4B connected with the USB-B port.
The print I started after upgrading the firmware, quickly ended with the following message
I searched in this forum to understand that it's a instruction Octoprint send to the printer when something is wrong to shut it down ASAP.
I disconnected Octoprint and tried to recalibrate the whole printer, starting with the Wizard.
A lot of the wizard was working correctly, but here and there I was getting weird errors each time different.
I succeeded to finish the wizard (except the first layer). I did the Belt test, the PID calibration, the new Temp profile.
But no matter what I do I get error erratically without any reason. I tried to downgrade to 3.11.1 (I think I was in 3.9.x) without no more luck.
I upgraded back to 3.12.1 to try to make a video to show what's happening :
Here's the video (cannot seem to embed it)
Could you help me find a solution ? Since everything was working perfectly before upgrading, I don't think the material broke instantly.
Thanks in advance for your help !
stay on firmware 3.11 while this gets sorted
RE: Is my mk3s+ haunted ?
dont worry about thermal anomaly thats only on 3.12 firmware and there still working on it or if you do want it make sure you calibrated properly
just to confirm you have tried without raspberry pi conected if so downgrade firmware by 4 then do it again
I tried to flash the firmware to 3.11 and the errors where still there. Not all of them but couldn't still print.
Yes, all the calibration a ran where without the raspberry pi connected. (The video is filmed without the raspberry pi/octoprint connected).
please factory reset printer
are you still getting z leveling enforced error
Ok, hang on, I'm going to try that and come back.
Thank you 😉
ok
I downgraded to 3.11.0. Did a factory reset and launched the wizard. It failed at the Axis. ( I never had any probleme with the axis oO).
Should I try to downgrade to 3.10.1 ?
Edit: Also when it gets out of the Wizard on the main screen i get the "MINTEMP HOTEND fixed. Please restart."
How's it going
My previous post is awaiting for moderation ...
Edit : this one doesn't.
Previous post >
I now tried to downgrade to 3.10.1 and I'm in the wizard and my Axis is fine now...
i sent you pm check it
how about the minitemp error fixed is that still comming up if not please post picture of your einsy rambo by the way if you keep getting moderation n
I think it would help them to report your issue on their Github. That's what I ended up doing.
https://github.com/prusa3d/Prusa-Firmware/issues
Aaron
Hi Extra Fox,
Thanks for your answer,
I contacted the Technical support of Prusa, I'll see what they have for an answer, as I don't know if it's just software or not.
I'll sure make a post on github to describe the problem if they ask me to do it. To help developer fix it.
I'll post if I have an answer that fix my problem here! 😉
