IR-Sensor Cable Issues
Anonymous
(@anonymous-3)
I was already having problems with my printer, and I did the selftest on my printer and it said "Filament sensor - wiring error" so I did a bit of research and a I think the IR-sensor cable is damaged but it doesn't look damaged can someone help me
Veröffentlicht : 28/12/2024 12:59 am
RE: IR-Sensor Cable Issues
wiring can suffer fatigue from constant flexing.
you could try stretching the wires to see where they broke... then repair them
You can repair the Filament sensor wire in a similar way to the image above
Joan
Veröffentlicht : 28/12/2024 1:47 pm
Anonymous
(@anonymous-3)
I tried stretching the cable and i didn't see any broken spots.
Veröffentlicht : 29/12/2024 2:37 pm
Have you checked for continuity?
Veröffentlicht : 29/12/2024 3:04 pm
Anonymous
(@anonymous-3)
what is continuity
Veröffentlicht : 29/12/2024 6:39 pm
use a test meter set to low ohms range to test each wire is connected from end to end.
https://www.wikihow.com/Test-Continuity-with-a-Multimeter
Veröffentlicht : 29/12/2024 7:11 pm
Anonymous
(@anonymous-3)
i tried that and all the wires are good
Veröffentlicht : 29/12/2024 10:30 pm
the filament sensor wiring needs to be correctly installed,
the top end is three wires
you may have a black PCB or a red PCB, and the connector clip should be on top.
the bottom connector can be on the wrong set of pins and it can be back to front,
please make sure they are the correct way round!
Veröffentlicht : 29/12/2024 11:29 pm
Anonymous
(@anonymous-3)
I checked the orientation and it still is giving me the error.
Diese r Beitrag wurde geändert Vor 1 year von Anonymous
Veröffentlicht : 30/12/2024 2:14 am
