[Resuelto] IR sensor
Corinne Laisne
(@corinne-laisne)
IR sensor
Hello everyone, my prusa mk3 has the following problem: the IR sensor has stopped working, the LCD screen does not detect the voltage of 4V. Can anyone help me? Thank you
Respondido : 26/10/2023 9:19 am
The first place to check when anything like this happens is loose connections - it's not alway the cause but dead easy to check and costs nothing...
With the machine OFF pull and replace all connections on the Einsy board and, in this case, if that doesn't help check the ribbon cables at the LCD end.
Let us now how you get on.
Respondido : 26/10/2023 3:02 pm
Corinne Laisne
(@corinne-laisne)
RE: IR sensor
Posted by: @diem
Yes thanks, I checked the connection and that is indeed the problem
Respondido : 27/10/2023 7:54 am
