Intermittent PINDA issues, worse when hot
E4R104
(@e4r104)
I have 2 MK3S printers that I run the living daylights out of.  This is the first time I've had this particular problem.  One is having bed leveling sensor fails intermittently.  They manifest much more frequently when the system is hot, PET type temps.  It happens cool too, when just running a z cal, but it more often than not works when cool and now is never working warmed up.  The light stays on when it fails even when the PINDA has smashed into the bed.  It happens at random points in the bed leveling process.  I've ordered a new sensor, but I wanted to make sure there isn't something else that might be contributing to this.  I rely heavily on these two printers.  I can limp along with one, but it creates issues for sure.
Thanks
Napsal : 02/01/2025 12:06 am
E4R104
(@e4r104)
RE: Intermittent PINDA issues, worse when hot
Well, miraculously found a PINDA v2 lying around. Swapped, problem solved. Just a duff sensor. Super pinda on the way anyways.
Napsal : 02/01/2025 2:12 am
