Installation problems
Novaspiro
(@novaspiro)
I have a custom Windows 7 installation where the user directory exists in another drive.  This enables a quick image recovery when windows fails since the Wind0ws recovery doesn't work.
I get the following errors:
boost::filesystem::directory_iterator::construct: The system cannot find the path specified: "C:\Users\Users\BHaidacherboost::filesystem::directory_iterator::construct: The system cannot find the path specified: "C:\Users\Users\BHaidacherboost::filesystem::directory_iterator::construct: The system cannot find the path specified: "C:\Users\Users\BHaidacherboost::filesystem::directory_iterator::construct: The system cannot find the path specified: "C:\Users\Users\BHaidacherboost::filesystem::directory_iterator::construct: The system cannot find the path specified: "C:\Users\Users\BHaidacher
This is created through a Junktion:
mklink /J E:\Users D:\Users, hence the directory seems to be there but it is on another drive.
You seem to access the files in a hard way and not using the OS.
Any command prompts to finetune this?
Respondido : 13/12/2019 10:12 pm
rmm200
(@rmm200)
RE: Installation problems
I am sorry, you seem to be on the wrong forum.
We deal here with the 3D printers made by Prusa. What product are you referencing?
Respondido : 14/12/2019 4:21 am
Novaspiro
(@novaspiro)
Is the Prusa Slicer part of the deal?
I think I am in the correct forum. Prusa slicer does not work. Hence, can't use my new Prusa Printer
Respondido : 14/12/2019 3:54 pm
There’s actually a Prusa slicer specific forum at the bottom, you have posted in the mk3 printer forum.  This is a peer to peer forum and I don’t think too many people will be able to help you with your custom configuration problem.
However you should raise an issue over on the Prusa slicer Github site at https://github.com/prusa3d/PrusaSlicer/issues where you are far more likely to get some useful feedback or help as the devs there check there.
Respondido : 14/12/2019 4:37 pm
rmm200
(@rmm200)
OK - nothing in your post referenced PrusaSlicer.
To get you going, use the samples on the SD card that came with your printer.
Any slicer will work; Cura is a popular one.
Make sure you download PrusaSlicer  from here: (And try downloading it again)
https://www.prusa3d.com/prusaslicer/
Respondido : 14/12/2019 4:40 pm
