[Rozwiązany] Input Voltage Einsy Rambo
Malte
(@malte-2)
Hi there,
my Printer isn't working ( LCD screen flashes blue)
I disconnected all cables
Firmware Updater can find the Printer but can't update it.
At both Inputs from the Einsy I can measure 5,3 Volts (that schould be 24 Volts or am I wrong?)
Fuses are all Ok
Don´t know what to do.
Opublikowany : 30/04/2020 11:45 am
RE: Input Voltage Einsy Rambo
I would expect to see 24 volts on the power connectors. have you tried taking the power cables off the power supply  connector strip! and measuring again
Opublikowany : 30/04/2020 12:56 pm
Malte
(@malte-2)
@joantabb
I disconnected both power supply cables, now I have 8.3 Volts. The failure starts at preheating the printer, maybe it's the power supply and hopefully not the board.
I will try it with an industrial power supply today.
Opublikowany : 01/05/2020 7:52 am
Malte
(@malte-2)
After connecting 24 Volts, the Printer works!
Opublikowany : 02/05/2020 8:48 am
Speak to chat (eShop page, bottom right hand corner, wait 5 seconds)  about the power supply
best wishes, Joan
Opublikowany : 02/05/2020 10:57 am
