Incorrect X Axis Length
nic
 nic
(@nic-3)
I am at a loss trying to diagnose an incorrect X axis length error.
I have:
-Taking the entire extruder apart
-Adjusted the belt twice
-Adjusted the X axis motor mount
-Loosened the X carriage mounting bracket screws
-Checked that the pulley by the PSU was rotating freely/not to tight
-Ensured none of the zip ties or wires are hitting the frame
When running the calibration wizard, the X axis reverses course about 1/2" before hitting the ends of the axis.
Any ideas or help is greatly appreciated.
Opublikowany : 16/11/2020 12:37 am
nic
 nic
(@nic-3)
RE: Incorrect X Axis Length
Update;
After continuing to fiddle fart around, it finally passed. I'm not exactly sure what the issue was or what I did to fix it.
I'll blame it on gremlins. Thanks to anyone who took the time to view this thread.
Opublikowany : 16/11/2020 4:23 am
Generally - 99.9% of the time, it is obstructions at the cable / rat-tail coming out the back of the extruder. The other 98% is dry bearings: with the extruder stopping before it hits the right bracket a clue for #2.
This post was modified 5 years temu by --
Opublikowany : 16/11/2020 5:19 am
