Incorrect ambient temp reading
Hello guys and girls,
I have problem with my Prusa MK3S. It says that ambient temperature is -34 degrees and print cannot start. Did you know how the Rambo board measure the ambient temperature and where I can find defective part?
Other workaround is to compile the firmware without this ambient temperature check but I don't know what I should disable in the source code.
Thank you!
Publié : 03/03/2023 8:46 pm
RE: Incorrect ambient temp reading
Check this out: https://help.prusa3d.com/article/ambient-temperature-check-mk3-mk3s_161230
Sounds like you need to get in touch with Prusa Customer Service.
Aaron
Publié : 03/03/2023 8:51 pm
