IN SEARCH OF: Optimized external perimeter speeds
After some great feedback and prodding from our community, I got my Linear Advance calibration process pretty well worked out. I next wanted to see the effects of external perimeter speeds on otherwise identical prints. I created a 10-step tower and starting at 15mm/s, increased speeds by 5mm/s for each step. I created both hollow and solid towers, with the solid tower appearing in the top of each pic. Here are screenshots showing the process:
Tower creation with layer modifiers:
Speed results:
Looking at the face printed along the X-axis:
  • As expected, echo picked up as speeds increased.
  • External perimeter speed seems to affect surface quality the most (no surprise) regardless of the speeds used for underlying layers (bit of a surprise).
  • Looking at the left side along the Y axis:
  • Quality does not degrade consistently with speed. At 30mm/s (level 4), there seems to be a lot of resonance. Quality improves at 40mm/s (level 6).
  • Looking at the right side along the Y axis:
  • 30mm/s (level 4) the resonance is consistent with the other side. 40 & 45mm/s (levels 6 & 7) look a little better.
  • Finally, looking from the rear along X:
  • 30mm/s (level 4) shows a bit more echo than I'd expect compared to 40mm/s (level 6).
  • Nothing too earth-shattering, but when developing Quality versus Speed settings:
  • 25mm/s for external perimeters is best for absolute surface quality, independent of the speeds used for other features. (Note: At least on small parts. Need to test more on larger parts.) This might be significant on prints with lots of infill.
  • The speed of external perimeters is significant whether the part is enclosed (solid) or open (hollow).
  • For speed profiles, 40-45mm/s may not yield worse results than 30mm/s.
  • Other things to try:
  • Try smaller steps to see where exactly things go bad around 30mm/s. Is this just my printer?
  • Tweak acceleration and jerk settings to see if better/acceptable surface quality is achievable at 40mm/s.
  • I've attached project and gcode files if anybody would like to try at home.
    Respondido : 05/04/2019 6:46 pm
    Re: IN SEARCH OF: Optimized external perimeter speeds
    I found start speed (jerk) and acceleration to be as important as actual print speed.
    Respondido : 06/04/2019 12:14 am
    I've actually done some testing with Jerk & Acceleration towers, but they require upping external perimeter speeds to 60 or so to show much benefit. I'm going to try adjusting them in conjunction with external speed tweaks. I'm wondering if it's possible to get 40-45mm/s external perimeters smoothed out.
    I was surprised at how little internal perimeters and infill matter to the final finish. I thought there'd be some cumulative effect, but I'm not seeing it.
    Respondido : 06/04/2019 12:36 am
    Top layer bleed through is where prior layers really show.
    Respondido : 06/04/2019 1:48 am
    [...] Top layer bleed through is where prior layers really show.
    I'm thinking a staircase-looking test part with a good-sized flat surface at each layer is the way to go, but it'll be a big print with too many levels. Perhaps built-in supports will help. Something new to try in OpenSCAD.
    Probably easier to create several flat-ish tiles and add speed modifiers to each.
    Respondido : 06/04/2019 4:10 am
    I'm thinking a staircase-looking test part ...
    I think it'd be tough to do all in one: since sub-layer 1 affects top layer, sub layer must be printed slower along with top layer.
    TL = slowest / SL1 =slower / SL2 = slow ...
    Could be done using short stacks for top surface, say 3 top layers. Change speed on height, and have a staircase of 10 x 40 to allow accel tests on the perimeters.
    Hard part is changing just the infill and top infill speed ... can't find a gcode command for that.
    Respondido : 06/04/2019 5:10 am
    [...] Hard part is changing just the infill and top infill speed ... can't find a gcode command for that.
    That can be done with the modifier parts. I'm thinking low cubes around the bed, each with modifiers to change infill speeds. I'll have to do some experimenting to find a reasonable size that lets the nozzle come up to speed on infill.
    Acceleration will require gcode and disabling the print setting acceleration settings by zeroing them out. I've got that part working.
    Respondido : 06/04/2019 9:24 am
    Make the infill perpendicular to the length ... allows for thin long sections at full speed. Make sure there are holes to mess with slice traces. Honestly, top layer quality at speed is the least of the troubles: mostly when the slicer does something silly. Just did a simple test from 100 mm/s down to 50 mm/s , and can't see any difference.
    Respondido : 06/04/2019 12:25 pm
    Jesper
    (@jesper)
    RE: IN SEARCH OF: Optimized external perimeter speeds
    Being new to the forum I hope my silly question will not be frowned upon - but where do I get my hands on the “attached” g-code file. I just can’t find it anywhere.
    Thanks in advance.
    Respondido : 26/04/2019 3:08 pm
    Unfortunately a lot of stuff got lost in the transition to the new form this week. I can re-generate the code easily enough. Do you have a range of LA values you want to test? Overly-tall towers take a long time to print.
    Respondido : 26/04/2019 4:21 pm
    Jesper
    (@jesper)
    I think the range you’ve shown here (15-60 mm/sec) will be a very good starting point. It will probably show my printers sweet-spot.
    If I need to test other speeds I guess I could simply do a simple replace of the different speeds in a text processor. Maybe you can give a hint to what I should search for.
    Thanks a lot for your helpfulness. 😊
    Respondido : 26/04/2019 8:01 pm
    Vojtěch
    (@vojtech)
    I'd be quite curious to try your gcode (or play with your project), too. I've upgraded my MK3R3 quite a bit and would like to compare if the resonances (your reason for ghosting getting worse around 30mm/sec) are better or not. Also, since I'm hunting the smaller aesthetic issues in prints now, Linear Advance tuning is also something that I'll need to look into.
    Respondido : 26/04/2019 8:52 pm
    Posted by: jesper kirkegaard.l
    I've uploaded some basic notes here on using modifiers for some settings in Slic3rPE. You can change speeds easily using that template. The notes are a little rough, but hopefully it's enough to get you started. Let me know if you have any questions. I'll try to get that page updated soon.
    Respondido : 27/04/2019 2:17 pm
    Posted by: vojtěch.p6
    The example here will get you started with speeds and things you can set in Slic3rPE easily. Setting Linear Advance and other settings requires a somewhat different technique using gcode. I'll try to put together some notes on that soon. Please let me know if you have any questions.
    Respondido : 27/04/2019 2:19 pm
    Jesper
    (@jesper)
    Ah -yes of course - you are using modifiers - why didn't I think of that ???
    Anyway thanks a lot for pointing me in the right direction - I am looking forward to some testing om my MK3S early next week - unfortunately I'm busy the next few days - can hardly wait.
    I think your observation, that the external perimeter speed is so important, is worth praise in itself. 🙂
    Again - thanks a lot.
    Respondido : 27/04/2019 10:06 pm
    Jesper
    (@jesper)
    ... and you are of course aware of Matt's Hub when it comes to Linear Advance tuning - right ?
    If not here's a link: https://mattshub.com/2017/10/02/linear-advance/
    It helped me get very fine seams on my prints.
    Respondido : 27/04/2019 10:24 pm
    Jesper
    (@jesper)
    Sorry - last post was to Vojtech-p6 !
    Respondido : 27/04/2019 10:25 pm
    I've attached an AMF that includes the 17 level Linear Advance test tower and associated settings. The Before layer change gcode contains all the magic for setting Linear Advance at each level. You can use essentially the same technique for testing changes in acceleration and jerk. I can easily generate some towers with the appropriate levels for those tests if you like.
    I've used the gcode from Matt's Hub and the Marlin test generator but I had some of the same problem as with the on-board Live-Z adjustment. Looking at a single extrusion tells you some things, but doesn't really show what impact changes have on adjacent layers. I find these bigger (and admittedly slower) prints useful for getting a feel for all of the impacts changing settings have on a complete print. The original thread describing these (gcode-driven) tests is here.
    Attachment removed
    Let me know if you have any questions or problems with the model and settings.
    Respondido : 28/04/2019 6:37 am
    Vojtěch
    (@vojtech)
    Thanks! No, I haven't used the Matt's Hub Linear Advance tuning yet. And yes, getting the seams tighter, particularly with some materials and when doing external perimeters first would be great. I'll give it a try.
    Respondido : 28/04/2019 8:02 am
