Impossible to find a DELTA FAN for mk3s+
Im searching all the internet to purchase 2 delta fans (for backup).
Tryed to purchase from prusa like 3 times, but they always ship Noctua Fans.
Noctua is 4500 rpm - Delta is 8000
Noctua is 4-4,5 cfm - Delta is 9 cfm
I only want to purchase this Delta Model.
Anyone knows where to find it?
The mini fan is the same? (it says its not compatible with mk3s+)
Help please
RE: Impossible to find a DELTA FAN for mk3s+
I thought prusa did send delta maybe try AliExpress
No luck in aliexpress.
I uploaded a photo from DELTA MK3s+ and DELTA from mini .....
Its the same fan.... I can not understand why Prusa says they are not compatible.....
Maybe the mini cable is shorter than the mk3 cable
It could be the conector
i have found lots on alixpress you just need to solder the old conector onto new fan search delta afb0405vha-a on alixpress
This are the properties of the MK3 print fan: Connector: Molex 5057-9403 Model name: NF-A4x10 Max RPM: 4500 Static pressure: 1,78 mm H₂O Airflow: 8,2 m³/h Input: 5V, 50mA
And this from the MINI+: Rated voltage: 5 VDC Input current: 0.11 (max 0.16) A Speed: 8000 RPM Max air flow (at zero static pressure): 15.72 m³/h Max air pressure (at zero airflow): 6.160 mm H₂O
hope this helps
