Imported STL file model size
Trying to pin down where the problem is, am very sure the stl file is correct, in the dimension details it is showing 2.4mm, but the overall height has 0.01mm extra showing 4.81, any reason why this would happen? Model has been designed to be 4.8 in height.
STL file attached.
Prusa i3 MK2s MK2.5s Mk3 Mk3s BearPrusa Zaribo 320 - Kit Build - Rc Driver - Tweak freak...
âI know nothing about surpassing others. I only know how to outdo myself.â -Bushido-
Opublikowany : 01/06/2020 4:10 pm
