i3 mk3s restarts when starting a print
Trumpf7206
(@trumpf7206)
I dont know if this has been posted before or not, but my mk3s restarts when starting a print from sd card. I normaly use octoprint but my modem died so I went back to sd card.
I sliced normaly with the octoprint configured prusa slicer, it restarted every time I tried to start a print.
When I sliced with a stock mk3s profile it worked perfectly.
(sry for any grammar error)
Postato : 01/05/2021 6:15 pm
RE: i3 mk3s restarts when starting a print
Posted by: @kukac95
Hello an welcome to the Prusaforum!
Actually it makes no difference if you send the gcode via Octoprint to the printer or if you print via SD card. Possibly your SD card is defective. I would test another one. You can also connect the Rapsberry to the network with a LANcable. You don't necessarily need WLAN.
For testing purposes you could upload a problematic gcode file (zip and "add media").
wbr,
Karl
Postato : 01/05/2021 7:34 pm
Trumpf7206
(@trumpf7206)
@karl-herbert
Hi
I attached an octoprint and a stock one in a zip, the "dead" sd card is a good idea.
Also i have thumbnail photo turned on in the octo one since web ui can show it, could that be a problem?
"Unfortunately" I have a pi zero w so wlan is not really an option.
THX for any help btw
GCODE
Postato : 01/05/2021 7:56 pm
Just in case: has it been long enough you've forgotten the X button is not ENTER?
Postato : 01/05/2021 8:29 pm
Trumpf7206
(@trumpf7206)
Wait i thought you supposed to mess the X button didn't ya??? 🤣
Postato : 01/05/2021 8:46 pm
@kukac95
The 8-bit einsy board cannot handle thumbnails. So if you print from SD card, you should remove them. Then the printer will not crash.
https://github.com/prusa3d/PrusaSlicer/issues/4127
wbr,
Karl
Postato : 01/05/2021 10:34 pm
1 persone hanno apprezzato
