i3 Mk3s Hotbed
Hi all,
I carried out a factory reset together a full calibration and the installation of the latest firmware due to the problem below.
The calibration identified NO faults and the bed heated up to the full temperature as expected.
I did a separate test to the hotbed and it heats up without problem, I have checked all cables and found nothing untoward.
However, when the SD card is inserted with a sliced file that I have used many times the hot end starts to heat up but not the bed.
Any help would be appreciated.
John W.
Opublikowany : 17/07/2024 6:08 pm
