I3 MK3S filament sensor mechanical problems
It was working beautifully, but now the switch seems to get stuck at filament present. Putting filament in manually doesn't change it unless I jerk it out, which seems to get the switch moving again. But as soon as I put filament back in, the switch gets stuck again. I'm sure it's a mechanical problem, (tested sensor and it's working fine).
Any suggestions on how to fix this?
Postato : 12/05/2020 7:50 pm
