I broke a 3D printed part in an assembly kit and can't find the STL.
[Gelöst] I broke a 3D printed part in an assembly kit and can't find the STL.
azs9
 azs9
(@azs9)
I bought the PRUSA I3 MK3S+ assembly kit.
I broke the 3D printed parts on both ends of the X-axis.
Since I have another 3D printer, I thought I would print the official STL.
I downloaded the file from this URL, but it seems to be an older version.
https://www.prusa3d.com/prusa-i3-printable-parts/
The part I broke had D1 and C6 stamped on it.
The parts in the file I was able to download were both R6.
x-end-idler
x-end-morter
Does anyone know where I can find the STL for D1 and C6?
Or will the R6 be the latest model?
Translated with www.DeepL.com/Translator (free version)
Best Answer by sca:
@azs9
It is my understanding that parts marked with A, B, C and D are parts printed on the Prusa print farm.  Parts marked with R are the equivalent parts printed elsewhere.
The R6 X-axis parts are the MK3s+ parts.
Dieses Thema wurde geändert Vor 5 years von azs9
Veröffentlicht : 08/06/2021 12:02 am
Mitglied
RE: I broke a 3D printed part in an assembly kit and can't find the STL.
 I am pretty sure that R6 is the new part.  Contact support via chat and they will tell you for certain.
Veröffentlicht : 08/06/2021 11:43 am
Tech support are probably your best bet as Charles says but if you want other older versions then they are located here https://github.com/prusa3d/Original-Prusa-i3/tree/MK3S/Printed-Parts
You can change the branch/tags using the button like icon and that will allow you to select other versions.
Veröffentlicht : 08/06/2021 12:28 pm
azs9
 azs9
(@azs9)
@cwbullet
Thank you!
Do you know which social network is the best for chatting?
In the meantime, I tried to contact you through Facebook.
Veröffentlicht : 08/06/2021 10:50 pm
azs9
 azs9
(@azs9)
RE: 組み立てキットの 3D プリント パーツを壊してしまい、STL が見つかりません。
@neophyl
Thank you!
I saw the old part on github.
It was similar to a part I had that I had broken, but the engraving was different.
Maybe it is an even older part.
Anyway, I will try to print the most recent parts of R6.
Veröffentlicht : 08/06/2021 10:53 pm
sca
 sca
(@sca)
@azs9
Veröffentlicht : 08/06/2021 11:03 pm
Mitglied
@azs9
PM me here.  Not much for facebook.
Veröffentlicht : 09/06/2021 1:15 am
azs9
 azs9
(@azs9)
Thank you all for your help.
I found out that the R code is up to date.
I also got a reply to a message I sent on Facebook.
They said that R is the latest.
I'll resume assembly with the parts I downloaded and printed!
Thank you so much!
Veröffentlicht : 09/06/2021 11:42 pm
